I have two of these modules, and spent a day trying to make them work... @.@
It sounds all simple: Connect GND, VCC, RX, TX, CH_PD, and then you could fire up Putty, set baud to 115200, and start experimenting with AT+ ....
Well, my module(s) didn't behave like that. I got gibberish over the terminal, then i got a continuous reset looking thingy when i went down to 9600 baud.
After a lot of reading, i gave it nice 3.3v, and over 9600 i got some gibberish then: [Vendor:www.ai-thinker.com Version:0.9.2.4] and ready!
Man, was i happy! Not for long, when i noticed none of the AT commands worked...
Ok, it seems i got it with not the AT firmware.
After finding a nice post, i downloaded firmware flasher, and flashed ESP_8266_BIN0.92.bin on it.
Reset, again some gibberish, but accepting AT commands! I could list tha access points, even reached a point when i could list the access points.
Getting no IP though.
Then i downloaded some chinese firmware flashing tool, that seemed to able to load stuff to different segments of memory. I could start some update nicely and it flashed the same garbage to my device that it was shipped with. Again no AT commands. Now i'm back to the first firmware, and i get responses from the module like:
AT+CWLAP?
output is: no this fun
Could switch it to MODE1, and got the list of AP available, and tried to connect to my own AP.
AT+CWJAP="WALLE","passs"
OK
AT+CWJAP?
+CWJAP:"WALLE"
OK
AT+CWMODE?
+CWMODE:1
OK
but AT+CIFSR keeps returning ERROR
When i switch to MODE3, CWLAP doesn't work either
AT+GMR returns: 00170901
It also likes to freeze up at AP+CWLAP
At this point any help is appreciated. O.o
Originally i had plans to write my own firmware, but what these modules showed so far is really disappointing.
