I have read that if a "virgin" ESP8266 is programmed via ArduinoIDE and if that sketch does not use any of the WiFi library functions, then the ESP8266 will be running in RF-disabled mode. I don’t know if this is true or not. And, if true, how to correct the situation.
It seems unlikely that the module is defective. WiFi is the only thing that doesn’t work correctly. I believe it is a software problem. Any ideas?
Oldmicroguy
