i plug my GPIOS to a relay, all works fine, but the problem is if i power down and turn back power on, than it cant find my ESP in wifi network, but if then i remove GPIO pins from the relays and then power back on it finds my ESP device in network.
the code im using is:
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
MDNSResponder mdns;
// Replace with your network credentials
const char* ssid = "xxxxxxxxxxxx";
const char* password = "xxxxxxxxxxxxxxxxxxxx";
ESP8266WebServer server(80);
String webPage = "";
int gpio0_pin = 0;
int gpio2_pin = 2;
void setup(void){
webPage += "<h1>HOME CENTRAL AUTOMATION</h1><p>RELAY 1 <a href=\"socket1On\"><button>ON</button></a> <a href=\"socket1Off\"><button>OFF</button></a></p>";
webPage += "<p><b>RELAY 2<a href=\"socket2On\"><button>ON</button></a> <a href=\"socket2Off\"><button>OFF</button></a></b></p>";
// preparing GPIOs
pinMode(gpio0_pin, OUTPUT);
digitalWrite(gpio0_pin, LOW);
pinMode(gpio2_pin, OUTPUT);
digitalWrite(gpio2_pin, LOW);
delay(1000);
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
if (mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("MDNS responder started");
server.on("/", [](){
server.send(200, "text/html", webPage);
server.on("/socket1On", [](){
digitalWrite(gpio0_pin, HIGH);
delay(1000);
server.on("/socket1Off", [](){
delay(1000);
server.on("/socket2On", [](){
digitalWrite(gpio2_pin, HIGH);
delay(1000);
server.on("/socket2Off", [](){
delay(1000);
server.begin();
void loop(void){
server.handleClient();
} i dont think it has nothing to do the code.
any toughts in what could be
