By Diviner
#57930 I have searched and can't find if this is possible without special wiring.
I just want to read the Arduino IDE input Serial Monitor command line as a way to simulate http calls. I have Both NL & CL set and 9600.
The serial monitor has no problem displaying
Code: Select allString inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
EDIT:
Figured it out. Needed
  while (Serial.available() > 0)
  Serial.begin(9600);
  inputString.reserve(200);
  if (stringComplete) {
    Serial.println(inputString);
    // clear the string:
    inputString = "";
void serialEvent() {
  while (Serial.available()) {
    char inChar = (char)Serial.read();
    inputString += inChar;
    if (inChar == '\n') {
      stringComplete = true;
