By ZsoltiD
#58161 I have a problem with my project. I started to create a program which can check the VCC and the temperature periodically and send them to a site (that save the data into DB).
I use DS18B20 sensor for recording the temperature and LD33CV voltage regulator for stable input Voltage.
My first problem is that ESP reads and sends about 3072 (3,072 Volts) and 22,56 Celsius to the DB, but the multimeter shows 3,300 Volts and the real temperature is 20,50 Celsius in the room.
The second problem is that I set 10 minutes for deep sleep mode, but the ESP woke up after about 9min 30 second.
It seems that there is relation between these two things (incorrect timer, and the wrong C/V values).
I uploaded the latest firmware (ESP8266_NONOS_SDK_2_0) but the problem has not been solved. :(
Do you have any idea?
Code: Select all// Including the ESP8266 WiFi library
#include <OneWire.h>
#include <DallasTemperature.h>
// Replace with your network details
const char* ssid = "xxxxx";
const char* password = "yyyyy";
float min = 10;
int vcc;
float tempC;
// Enable ADC MODE for VCC scanning
ADC_MODE(ADC_VCC);
// Data wire is plugged into pin D1, GPIO 2
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature DS18B20(&oneWire);
char temperatureCString[6];
char temperatureFString[6];
const char* host = "xyxyxyxy.com";
// only runs once on boot
  // Initializing serial port for debugging purposes
  delay(10);
  // Display MAC Address
  String MAC_ADDR = WiFi.macAddress();
  // IC Default 9 bit.
  DS18B20.begin();
  // Connecting to WiFi network
  WiFi.begin(ssid, password);
    Serial.print(".");
  // Get actual VCC
  vcc = ESP.getVcc();
  delay(20);
  // last two bytes of the MAC (HEX'd) for the DB:
  uint8_t mac[WL_MAC_ADDR_LENGTH];
  WiFi.softAPmacAddress(mac);
  String macIDend = String(mac[WL_MAC_ADDR_LENGTH - 2], HEX) +
                 String(mac[WL_MAC_ADDR_LENGTH - 1], HEX);
  // Get temperature
  do {
    DS18B20.requestTemperatures();
    tempC = DS18B20.getTempCByIndex(0);
    dtostrf(tempC, 2, 2, temperatureCString);
    delay(100);
  } while (tempC == 85.0 || tempC == (-127.0));
  WiFiClient client;
  const int httpPort = 80;
    return;
  client.print(String("GET /insert_temp_logs.php?temp_id=" + macIDend +"&temp_val=" + temperatureCString +"&temp_vcc=" + vcc + "") + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  Serial.print("Going to sleep.");
  //sleep and try again
  ESP.deepSleep(min * 60000000); //val * 1 min
void loop(void)
