I want to Know , if i can Get Public IP of my Router through ESP8266 ?
ESP8266 Connects --> Router --> ESP Gets to Know Public IP and Stores it.
Is there any Arduino Code Lines for this ?
Explore... Chat... Share...
void GetExternalIP()
WiFiClient client;
if (!client.connect("api.ipify.org", 80)) {
Serial.println("Failed to connect with 'api.ipify.org' !");
else {
int timeout = millis() + 5000;
client.print("GET /?format=json HTTP/1.1\r\nHost: api.ipify.org\r\n\r\n");
while (client.available() == 0) {
if (timeout - millis() < 0) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
int size;
while ((size = client.available()) > 0) {
uint8_t* msg = (uint8_t*)malloc(size);
size = client.read(msg, size);
Serial.write(msg, size);
free(msg);
WiFiClient client;
client.stop();
return;
int size;
terminal.flush();
terminal.write(msg, size);
terminal.flush();
free(msg);
}It takes about 20-25 seconds for home assistant c[…]
