By mydroid76
#59200 So needing a basic web server with a button to activate a pin that I will have a switch on to open/close a gate. Got the page up with a button that activates the default led pin for now. I'm using this from a phone, so the problem I'm having is after the button is pressed, if I hit the back button it connects as a new client, and if I press back again to close out of the browser the client stays connected and I have to reset the controller. I put in a controller reset for now as a work around, but I have a feeling it will get hung up again in just the right setting and won't be able to control it when needed. I'm sure it is a simple fix, but just getting started as you can tell from my code. I was able to reverse engineer some examples I found online and piece together what I have. Also if there is anyway that after x number of seconds after displaying "Gate Button Pressed" it can go back to the initial page would be nice too. Thanks, and any help is appreciated.
#include <SPI.h>
const char* ssid = "SSID";
const char* password = "Password";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(8080);
delay(10);
// prepare LED_BUILTIN pin
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, 0);
// Connect to WiFi network
Serial.println(ssid);
IPAddress ip(192,168,1,176);
IPAddress gateway(192,168,1,254);
IPAddress subnet(255,255,255,0);
WiFi.begin(ssid, password);
WiFi.config(ip,gateway,subnet);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
//Declare reset function @ address 0
void(* resetFunc) (void) = 0;
if (!client) {
return;
Serial.println("new client");
while(!client.available()){
delay(1);
Serial.println(req);
client.flush();
String IP = WiFi.localIP().toString();
// client.print("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now </html>\n");
client.print("<html>");
client.print("<FORM action=/gate"">");
client.print("<input type=""submit"" value=""Gate"" style=""height:300px;width:300px"">");
client.print("</form>");
client.print("</html>");
client.flush();
//client.stop();
// Match the request
int val;
if (req.indexOf("/gate")!=-1)
val=1;
else {
Serial.println("invalid request");
client.stop();
return;
// Set LED_BUILTIN On sleep 500 ms then LED_BUILTIN off
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
client.flush();
//Prepare the response
client.print("<html>\r\nGate Button Pressed! </html>\n");
delay(1);
Serial.println("Client disonnected");
delay(5000);
resetFunc(); //call reset
