Here are my functions:
struct espconn conn1;
struct espconn conn2;
esp_tcp tcp1;
esp_tcp tcp2;
void connectCB(void *arg) {
os_printf("We have connected\n");
void errorCB(void *arg, sint8 err) {
os_printf("We have an error: %d\n", err);
void disconnectCB(void *arg) {
os_printf("Disconnected\n");
/* |< Using conn1 connect to first port >| */
void connect1() {
conn1.proto.tcp->remote_port = REMOTE_PORT;
*((uint32 *)conn1.proto.tcp->remote_ip) = ipaddr_addr(REMOTE_IP);
espconn_connect(&conn1);
os_printf("Inside connect1\n");
/* |< Using conn2 connect to other port>| */
void connect2() {
conn2.proto.tcp->remote_port = REMOTE_PORT2;
*((uint32 *)conn2.proto.tcp->remote_ip) = ipaddr_addr(REMOTE_IP2);
espconn_connect(&conn2);
os_printf("Inside connect2\n");
}Below is User_init:
void ICACHE_FLASH_ATTR user_init(void) {
uart_param_t para;
para.uart_baud_rate = UART_BAUD_RATE_115200;
para.uart_xfer_bit = UART_XFER_8_BIT;
para.uart_parity_mode = UART_PARITY_NONE;
para.uart_stop_bit = UART_1_STOP_BIT;
para.uart_flow_ctrl = UART_NONE_FLOW_CTRL;
uart0_init(¶);
/* TCP init */
conn1.type = ESPCONN_TCP;
conn1.state = ESPCONN_NONE;
conn1.proto.tcp = &tcp1;
espconn_regist_connectcb(&conn1, connectCB);
espconn_regist_reconcb(&conn1, errorCB);
espconn_regist_disconcb(&conn1,disconnectCB);
conn2.type = ESPCONN_TCP;
conn2.state = ESPCONN_NONE;
conn2.proto.tcp = &tcp2;
espconn_regist_connectcb(&conn2, connectcb);
espconn_regist_reconcb(&conn2, errorcb);
espconn_regist_disconcb(&conn2,disconnectCB);
espconn_init();
