I'm using the ESP8266 wireless transceiver module with an Arduino UNO. The module is working as expected (I've tested my configuration with several sample projects I found on the net).
For ease of testing I've set things up so that I can communicate directly with the ESP8266 via the Serial Monitor window. Here are the commands I use to get things going:
// What firmware version is installed?
AT+GMR
0018000902-AI03
// Reset the device
AT+RST
OK
L(CÇäÿZNÿbc@þD@JSÀàà
[Vendor:www.ai-thinker.com Version:0.9.2.4]
ready
// Set the data transmission mode (1 is "data mode")
AT+CWMODE=1
no change
// Connect the ESP8266 to my access point
AT+CWJAP="XXXX","XXXX"
OK
// What is the ESP8266's ip address?
AT+CIFSR
192.168.161.27
// Start a TCP connection with google
AT+CIPSTART="TCP","www.google.com",80
OK
LinkedAt this point I know I have to perform an
AT+CIPSEND=XAT+CIPSEND=37
> GET / HTTP/1.1\r\NHnost: google.com
SEND OK
I get back a "SEND OK" but I never get the expected html data. Does anyone see what I am doing wrong here?
Thank you in advance!
