By basit701
#60644 Hello Guys i have written a code to read data from RX (ESP8266) and transmit it to freeboard.io . But the problem is that:
Code: Select all b=String("GET /dweet/for/uetmpsproject?temperature=") + String(t) + String("&humidity=") + String(a) + String(" HTTP/1.1\r\n") + String("Host: ") + host + String("\r\n") + String("Connection: close\r\n\r\n");
  client.print(b);
does not execute when serial data is read. i.e (when RX buffer gets some data from sensor).
the code is:
Code: Select all// Import required libraries
#include "ESP8266WiFi.h"
// WiFi parameters
const char* ssid = "TP-LINK_4A8154";
const char* password = "honda125";
// Host
const char* host = "dweet.io";
int temp = 0;
String a;
String b;
  // Start Serial
  delay(10);
  // Init DHT
  //dht.begin();
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
 temp = temp +1;
  Serial.println(host);
  WiFiClient client;
  const int httpPort = 80;
    return;
  a = Serial.readString();
 delay(20);
  int t = temp;
  client.print(b);
  delay(10);
  while(client.available()){
    Serial.print(line);
  // Repeat every 10 seconds
  delay(10000);
