The other 8 boards are working great. There are able to connect to my wifi, I can easily connect to their AP.
If I try to run a wifi network scan code on my faulty boards, they only detect my home network like once or twice in 20 - 25 scans, but their were two networks which were more than thrice the distance away from my own router, but the esp would still discover it every time. I then tried to connect them to other network but still they couldn't connect.
I am not able to figure out why is this happening.
1. I am able to get response from the esp, means that my hardware it working fine.
2. All other modules are able to connect to my router. Means their is no issue with router channel or anything like that.
3. No scratches on PCB
4. I though that I might have had a loose solder joint while soldering, so i re-soldered most of the parts.
5. While working with a faulty board, all my other esp's are disconnected, so network is also not populated.
Does anyone known's a possible reason of this problem and can help me solve it.
Thanks in advance.
