By nikan110
#64769 hi to all, i am working on a project that in it i need to send some file over wifi from my computer to my micro and i decide to use esp8266 in order to done that. i use below code for my esp8266 to recive file and redirect it to uart port :
uint8_t data = 0;
WiFiServer server(8888);
int counter = 0;
  WiFi.softAP("akbar","akbar11041");
  server.begin();
   WiFiClient con = server.available();
   if(con)
      Serial.println("new connection");
      counter = 0;
      while(con.connected())
        if(con.available())
          counter += con.read(&data,1);
          Serial.print(data);
      Serial.println("Connection closed");
      Serial.println("number of items :");
      Serial.println(counter);
      con.stop();
and use below python code for sending file :
Code: Select allimport socket
import time
fl = open("3.dat","rb")
data = fl.read()
con = socket.socket(socket.AF_INET,socket.SOCK_STREAM)
con.connect(("192.168.4.1",8888))
print(con.send(data))
fl.close()
but i have a problem, as you can see i send every byte that i receive to Serial port, but for example when i sent a file that has 768000 byte i only receive 5000 byte of that file in esp and also in uart.
now can any one help me to solve that, it offend me for tow day.
