I'm trying to setup a tcp server on the ESP8266, but I always get a error with the "proto.udp"
invalid type argument of '->' (have 'struct espconn')Any idea ?
Jannik Jung
Explore... Chat... Share...
invalid type argument of '->' (have 'struct espconn')#include "espconn.h"
#include "mem.h"
#include "user_interface.h"
static struct espconn *pUdpServer;
void user_init(void)
pUdpServer = (struct espconn *)os_zalloc(sizeof(struct espconn));
ets_memset( pUdpServer, 0, sizeof( struct espconn ) );
espconn_create( pUdpServer );
pUdpServer->type = ESPCONN_UDP;
pUdpServer->proto.udp = (esp_udp *)os_zalloc(sizeof(esp_udp));
pUdpServer->proto.udp->local_port = 7777;
espconn_regist_recvcb(pUdpServer, udpserver_recv);
if( espconn_create( pUdpServer ) )
while(1) ;
}It takes about 20-25 seconds for home assistant c[…]
