I know how to push file on flash thru Arduino IDE, but i don't know how to set right path to access this file from page build by ESP.
Thanks for you answers
Manu
Explore... Chat... Share...
if (!SPIFFS.begin()) {
Serial.println("SPIFFS failed to mount !\r\n");
else {
Dir dir = SPIFFS.openDir("/");
while (dir.next()) {
Serial.print(dir.fileName());
Serial.print(" - ");
Serial.println(dir.fileSize());
