- Thu May 18, 2017 3:40 am
#66031
Hi fellow ESP users. I am having a problem with my NodeMCU. If I connect the TXD0 pin to low via resistor the device will not boot and run my app. Seems to go into flash mode. However if I tie it to 3V3 via resistor all is fine. The reason I am doing this is to convert the 3v3 UART lines to RS232 levels without using a MAX chip. Not ideal for TX, but works fine. Using the circuit below (top part). Effectively, TXD is tied LOW by the resistor pair.
A cap in series with resistor from TTL (NodeMCU) TXD to VCC works in keeping TXD HIGH on boot-up, but then I have to always power cycle to reset so that cap can discharge.
My real question is why does the device not boot into program when TXD0 is LOW.
