I'm needing help to build a project and I'm looking to use a library for my ESP8266 module in my ARDUINO UNO.
If you know a Library to use the ESP8266 I appriciate it.
I need the arduino reading the DB every time to receive a simple value 0 or 1, I just need to know how to receive this answer.
portaoeletronico.esy.es/recebe.php (I NEED TO READ THIS BODY)
At the moment I am not able to make a code on the arduino with this library: https://github.com/itead/ITEADLIB_Arduino_WeeESP8266
That makes the GET request work, could someone show me a code that would work? Thank you.
My PHP:
Code:
<?php
$servername = "mysql.hostinger.com.br";
$username = "root";
$password = "*****";
$dbname = "esp1";
$conn = new mysqli($servername, $username, $password);
header("content-type: application/json");
$sql = "SELECT * FROM `u582151594_esp82`.`esp1`";
$result = $conn->query($sql);
while($data = $result->fetch_object()) {
$value = $data->value;
echo '{"value":';
echo $value;
echo '}';
$conn->close();
?>The code returns me:
{"value":0}
I need the arduino to read this JSON, parse, and remove this VALUE for me to use in my code.
Some help?
Thankss
