- Thu Feb 05, 2015 12:43 pm
#9075
Hi again,
I found the reason in pwm.c line 25; I added the 4. item:
Code: Select allLOCAL uint8 pwm_out_io_num[PWM_CHANNEL] = {PWM_0_OUT_IO_NUM, PWM_1_OUT_IO_NUM, PWM_2_OUT_IO_NUM, PWM_3_OUT_IO_NUM};
By that the 4 PWM outputs on GPIO12,13,14,2 work properly
but unfortunatly only for a while
The program in ESP is a modified esphttpd and gets a lot of commands from NETIO-APP to modify the duty cycle. After about 100-200 commands the program crashes with:
Code: Select allmalloc assert!
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x40100000, len 28300, room 16
tail 12
chksum 0x4a
ho 0 tail 12 room 4
load 0x3ffe8000, len 2924, room 12
tail 0
chksum 0x66
load 0x3ffe8b70, len 5772, room 8
tail 4
chksum 0x10
csum 0x10
r
ESP8266 in STATION mode, restarting in STATION mode...
My modifications do not use malloc, so perhaps any one can find the error by looking at the printout??
Regards
