Take a magnifying glass and make a note of the characters on it.
If all's well, the partnumber you need starts with 25C (or 25Q) followed by a number, look that number up here:
- 05 = 512kbit (64kx8)
10 = 1Mbit (128kx8)
20 = 2Mbit (256kx8)
40 = 4Mbit (512kx8)
80 = 8Mbit (1024kx8)
16 = 16Mbit (2048kx8)
32 = 32Mbit (4096kx8)
64 = 64Mbit (8192kx8)
128 = 128Mbit (16384x8)
256 = 256Mbit (32768x8)
Patti4832 wrote:Hello,
Is this a 4MBit version or what type is it?
I recently stumbled on this and it's very handy. It even gave me a surprise when I discovered that one of my ESP-01's in the spares drawer actually had a 16Mbit (2Mbyte) flash on it!
espinfo.cpp
#include <Arduino.h>
#include "FS.h"
// wait a few seconds before we begin
delay(4000);
String realSize = String(ESP.getFlashChipRealSize());
String ideSize = String(ESP.getFlashChipSize());
bool flashCorrectlyConfigured = realSize.equals(ideSize);
FSInfo fs_info;
if(flashCorrectlyConfigured){
SPIFFS.begin();
Serial.println("flash correctly configured, SPIFFS started, IDE size: " + ideSize + ", real size: " + realSize);
else Serial.println("flash incorrectly configured, SPIFFS cannot start, IDE size: " + ideSize + ", real size: " + realSize);
SPIFFS.info(fs_info);
Serial.println("\nVery basic Spiffs example, writing 10 lines to SPIFFS filesystem, and then read them back");
SPIFFS.begin();
if (!SPIFFS.exists("/formatComplete.txt")) {
Serial.println("Please wait 30 secs for SPIFFS to be formatted");
SPIFFS.format();
//delay(30000);
Serial.println("Spiffs formatted");
File f = SPIFFS.open("/formatComplete.txt", "w");
if (!f) {
Serial.println("file open failed");
} else {
f.println("Format Complete");
} else {
Serial.println("SPIFFS is formatted. Moving along...");
delay(3000);
float fileTotalKB = (float)fs_info.totalBytes / 1024.0;
float fileUsedKB = (float)fs_info.usedBytes / 1024.0;
float flashChipSize = (float)ESP.getFlashChipSize() / 1024.0 / 1024.0;
float realFlashChipSize = (float)ESP.getFlashChipRealSize() / 1024.0 / 1024.0;
float flashFreq = (float)ESP.getFlashChipSpeed() / 1000.0 / 1000.0;
FlashMode_t ideMode = ESP.getFlashChipMode();
Serial.printf("\n#####################\n");
Serial.printf("__________________________\n\n");
Serial.println("Firmware: ");
Serial.printf(" Chip Id: %08X\n", ESP.getChipId());
Serial.print(" Core version: "); Serial.println(ESP.getCoreVersion());
Serial.print(" SDK version: "); Serial.println(ESP.getSdkVersion());
Serial.print(" Boot version: "); Serial.println(ESP.getBootVersion());
Serial.print(" Boot mode: "); Serial.println(ESP.getBootMode());
Serial.println("Flash chip information: ");
Serial.printf(" Flash chip Id: %08X (for example: Id=001640E0 Manuf=E0, Device=4016 (swap bytes))\n", ESP.getFlashChipId());
Serial.printf(" Sketch thinks Flash RAM is size: "); Serial.print(flashChipSize); Serial.println(" MB");
Serial.print(" Actual size based on chip Id: "); Serial.print(realFlashChipSize);
Serial.println(" MB ... given by (2^( 'Device' - 1) / 8 / 1024");
Serial.print(" Flash frequency: "); Serial.print(flashFreq); Serial.println(" MHz");
Serial.printf(" Flash write mode: %s\n", (ideMode == FM_QIO ? "QIO" : ideMode == FM_QOUT ? "QOUT" : ideMode == FM_DIO ? "DIO" : ideMode == FM_DOUT ? "DOUT" : "UNKNOWN"));
Serial.println("File system (SPIFFS): ");
Serial.print(" Total KB: "); Serial.print(fileTotalKB); Serial.println(" KB");
Serial.print(" Used KB: "); Serial.print(fileUsedKB); Serial.println(" KB");
Serial.printf(" Block size: %lu\n", fs_info.blockSize);
Serial.printf(" Page size: %lu\n", fs_info.pageSize);
Serial.printf(" Maximum open files: %lu\n", fs_info.maxOpenFiles);
Serial.printf(" Maximum path length: %lu\n\n", fs_info.maxPathLength);
Dir dir = SPIFFS.openDir("/");
Serial.println("SPIFFS directory {/} :");
while (dir.next()) {
Serial.print(" "); Serial.println(dir.fileName());
Serial.println(" "); Serial.println(dir.fileSize());
Serial.printf("CPU frequency: %u MHz\n\n", ESP.getCpuFreqMHz());
Serial.print("#####################");
// open file for writing
File f = SPIFFS.open("/f.txt", "w");
if (!f) {
Serial.println("====== Writing to SPIFFS file =========");
// write 10 strings to file
for (int i=1; i<=10; i++){
f.print("Millis() : ");
f.println(millis());
Serial.println(millis());
f.close();
// open file for reading
f = SPIFFS.open("/f.txt", "r");
if (!f) {
} Serial.println("====== Reading from SPIFFS file =======");
String s=f.readStringUntil('\n');
Serial.print(i);
Serial.print(":");
Serial.println(s);
delay(1000);
treii28 wrote:I discovered that one of my ESP-01's in the spares drawer actually had a 16Mbit (2Mbyte)
If I recall correctly, at the very first early ESP-01 even had only 1MB ...
