Cp2102 problem
Posted: Thu Feb 12, 2015 10:56 am
I'm trying to upload a nodemcu script using a cp2102, it come mounted on /dev/ttyUSB0 but it can't communicate with the module. All the wires connection are ok, and I've also tried with a Windows pc and it work , so the problem is software side. This is the dmesg output:
[ 3144.796181] usb 5-1: new full-speed USB device number 70 using uhci_hcd
[ 3144.957166] usb 5-1: New USB device found, idVendor=10c4, idProduct=ea60
[ 3144.957174] usb 5-1: New USB device strings: Mfr=1,Product=2,SerialNumber=3
[ 3144.957180] usb 5-1: Product: CP2102 USB to UART Bridge Controller
[ 3144.957184] usb 5-1: Manufacturer: Silicon Labs
[ 3144.957188] usb 5-1: SerialNumber: 0001
[ 3144.962334] cp210x 5-1:1.0: cp210x converter detected
[ 3144.964477] usb 5-1: cp210x converter now attached to ttyUSB0
and this what appear when I try to upload the code:
python luatool.py -p /dev/ttyUSB0 -b 9600 -f webserver.lua -t webserver.lua
s->file.open("webserver.lua", "w")Traceback (most recent call last):
File "luatool.py", line 118, in <module>
writeln("file.open(\""+args.dest+"\", \"w\")\r")
File "luatool.py", line 41, in writeln
raise Exception('No proper answer from MCU')
Exception: No proper answer from MCU
