By rdady
#70284 Hi folks, I need your experienced help! :)
I have 2 boards wired up to a breadboard.
A) Wemos esp8266-12F
B) Arduino pro micro mega32u4
Grounds are connected, Vcc-s are connected and A:RX is connected to B:TX.
A:RX/TX pins are -> Serial as these pins are fed to USB/SERIAL IC
B:RX/TX pins are -> Serial1 as atmega32u4 uses dedicated pins for USB and RX/TX is available on Serial1
Here is my code on A:
Code: Select allvoid setup() {
    while (!Serial) {
byte rx_byte = 0;        // stores received byte
  Serial.println("hello world!");
  delay(100);
Here is my code on B:
  Serial1.begin(115200);
  while (!Serial) {  }
  while (!Serial1) {  }
byte inByte = 0x0;
byte str[50] = "";
byte *pstr;
  if (Serial1.available() > 0) {
    *pstr = Serial1.read();
    Serial.print((char) *pstr);
    Serial.println(pstr - str);
    pstr++;
  } else {
    *pstr = 0;
    pstr = str;
