So far all the NTP libraries I've seen do not allow to have a precision below the seconds.
The most promising alternative I found is this nice article (https://www.geekstips.com/arduino-time- ... p8266-udp/), which describes how to get the time from reading the UDP packets.
Unfortunately it's a little unclear to me how I should change the code to get the milliseconds.
Can anyone help me?
This is the core of the code:
int cb = udp.parsePacket();
if (!cb) {
Serial.println("no packet yet");
else {
Serial.print("packet received, length=");
Serial.println(cb);
// We've received a packet, read the data from it
udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, esxtract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
Serial.print("Seconds since Jan 1 1900 = " );
Serial.println(secsSince1900);
Thanks!
