system_adc_read_fast (uint16 *adc_addr, uint16 adc_num, uint8 adc_clk_div)However, when I print out the values stored in adc_addr, I always get 1024. Why is this?
I have a NodeMCU v3. I have connected an electret microphone to it. +ve terminal is connected to 3.3V through 10k; GND is connected to GND. +ve terminal is connected to A0 on NodeMCU.
It works fine when I use system_adc_read() (except the sampling rate is then 10ksps which is not desirable).
This is the code I'm using:
// Expose Espressif SDK functionality - wrapped in ifdef so that it still
// compiles on other platforms
#ifdef ESP8266
extern "C" {
#include "user_interface.h"
#endif
#define num_samples 256
uint16_t adc_addr[num_samples];
uint16_t adc_num = num_samples;
uint8_t adc_clk_div = 32;
int i = 0;
unsigned long start = 0;
unsigned long total = 0;
unsigned long tim = 0;
#ifdef ESP8266
//Serial.println(system_get_sdk_version());
start = micros();
// uint16 *adc_addr : point to the address of ADC continuously fast sampling output.
// uint16 adc_num : sampling number of ADC continuously fast sampling, range [1, 65535].
// uint8 adc_clk_div: ADC working clock = 80M/adc_clk_div, range [8, 32], the recommended value is 8.
wifi_set_opmode(NULL_MODE);
system_soft_wdt_stop();
ets_intr_lock( ); //close interrup
noInterrupts();
system_adc_read_fast(adc_addr, adc_num, adc_clk_div);
unsigned int tot = micros() - start;
interrupts();
ets_intr_unlock(); //open interrup
system_soft_wdt_restart();
tim += tot;
total += num_samples * 1000000.0 / tot;
i++;
if (i == 100) {
// Serial.print("Sampling rate: ");
// Serial.println(total / 100);
// Serial.print("It lasted: ");
// Serial.println(tim / 100);
i = 0;
tim = 0;
total = 0;
for (int j=0; j<adc_num; j++) {
Serial.println(adc_addr[j]);
#endif
