WiFi.printDiag(Serial);
Configuring access point...Mode: AP
PHY mode: G
Channel: 1
AP id: 0
Status: 255
Auto connect: 1
SSID (0):
Passphrase (0):
BSSID set: 0
AP IP address: 192.168.4.1
HTTP server started
The script I'm currently trying to run is:
/* Create a WiFi access point and provide a web server on it. */
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
/* Set these to your desired credentials. */
const char *ssid = "ESPap";
const char *password = "12345678";
ESP8266WebServer server(80);
/* Just a little test message. Go to http://192.168.4.1 in a web browser
* connected to this access point to see it.
void handleRoot() {
server.send(200, "text/html", "<h1>You are connected</h1>");
delay(1000);
Serial.print("Configuring access point...");
/* You can remove the password parameter if you want the AP to be open. */
WiFi.disconnect(true);
WiFi.setAutoConnect(false);
WiFi.setPhyMode(WIFI_PHY_MODE_11G);
WiFi.softAP(ssid, password);
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on("/", handleRoot);
server.begin();
server.handleClient();
Authentication problem
