Thanks in advance for any help you can give.
Explore... Chat... Share...
const char* ssid = "your-ssid";
const char* password = "your-password";
const char* host = "192.168.4.1";
const char* command = "sleep 10";
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
delay(5000);
Serial.println(host);
WiFiClient client;
const int httpPort = 7777;
return;
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
client.print(String("\r\n") + String(command) + String("\r\n"));
while(client.available()){
char line[1024];
int len = client.read((uint8_t*)line, sizeof(line-1));
line[len] = '\0';
Serial.print(String(line));
}It takes about 20-25 seconds for home assistant c[…]
