unsigned long currentMillis = millis();should ideally be placed in a sketch, so that currentMillis can be retrieved from commands within the loop() and also from within functions.
Explore... Chat... Share...
unsigned long currentMillis = millis();It takes about 20-25 seconds for home assistant c[…]
