with a 4x4 keypad to switch my door (in the future)
i was trying my sketch
but the device keeps goin on SOFT RESET while in the WHILE LOOP
i do not really understand why... i tried the same code with an arduino NANO and it worked
actually it is perfectly working on ESP too except that if i wait too much time after a key-press it goes on SOFT RESET.
this is the code:
/*4x4 Matrix Keypad connected to Arduino
This code prints the key pressed on the keypad to the serial port*/
#include <Keypad.h>
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 4; //number of columns on the keypad
int buzz = D8;
String s ="";
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[numRows] = {D7,D6,D5,D4}; //Rows 0 to 3
byte colPins[numCols]= {D3,D2,D1,D0}; //Columns 0 to 3
//initializes an instance of the Keypad class
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
void setup()
pinMode(buzz, OUTPUT);
Serial.begin(9600);
//If key is pressed, this key is stored in 'keypressed' variable
//If key is not equal to 'NO_KEY', then this key is printed out
//if count=17, then count is reset back to 0 (this means no key is pressed during the whole keypad scan process
void loop(){
char keypressed = myKeypad.getKey();
if (keypressed != NO_KEY)
suona();
s = s + keypressed;
Serial.println(s);
int tempo_zero = millis();
press_loop();
void press_loop(){
int n = 0;
int tempo = millis();
while (n<5){
Serial.println("WHILE");
char k = myKeypad.getKey();
if (k != NO_KEY){
s = s + k;
Serial.println(s);
suona();
n = n + 1;
tempo = millis();
if (tempo-tempo_zero>20000) break;
delay(350);
if (s == "00000#") suono_on();
else suono_off();
s = "";
Serial.println("");
void suona() {
tone(buzz, 1400); // Send 1KHz sound signal...
delay(100); // ...for 1 sec
noTone(buzz);
void suono_off() {
tone(buzz, 1000); // Send 1KHz sound signal...
delay(200); // ...for 1 sec
noTone(buzz);
delay(50);
tone(buzz, 200);
delay(400);
noTone(buzz);
void suono_on() {
tone(buzz, 1500);
delay(200);
noTone(buzz);
delay(50);
tone(buzz, 1500);
delay(200);
noTone(buzz);
delay(50);
tone(buzz, 1500);
delay(200);
noTone(buzz);
and this is where the device RESET:
while (n<5){
if (k != NO_KEY){
s = s + k;
Serial.println(s);
suona();
n = n + 1;
tempo = millis();
}any idea?
