They've been randomly not sending data. I manually power cycle them and their fine for a bit. Finally put on up on the bench to see. No error is thrown, they still show on the network but they just don't do anything.
That being said I started to look at the esp's watchdog timers and I'm a bit confused. https://techtutorialsx.com/2017/01/21/e ... functions/ If I'm reading that right the integer send along with wdtEnable doesn't matter. Looks like its about 6 seconds.
So my question, is there a way to set a 30 second or so timer to reset if not reset? Or is there a better way to implement this so they stop hanging.
#include <DHT.h>
#define DHTTYPE DHT22 // DHT 11
const char* ssid = "HexHome";
const char* password = "xxxxxxxxx";
const char* host = "api.hexhome.int";
const int port = 80;
// DHT Sensor
const int DHTPin = 2;
DHT dht(DHTPin, DHTTYPE);
HTTPClient http;
void setup () {
delay(10);
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.hostname("LivingRoomESP");
WiFi.begin(ssid, password);
delay(1000);
Serial.print(".");
Serial.println("");
if (WiFi.status() == WL_CONNECTED) {
HTTPClient http; //Declare an object of class HTTPClient
float h = dht.readHumidity();
float f = dht.readTemperature(true);
if (isnan(h) || isnan(f)) {
Serial.println("Failed to read from Sensor!");
else{
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t Temperature: ");
Serial.print(f);
Serial.println(" *F");
String url = "/thlog";
url += "?nodeName=";
url += "Living_Room";
url += "&temperature=";
url += String(f);
url += "&humidity=";
url += String(h);
sendAPI(url);
delay(30000); //Send a request every 30 seconds
void sendAPI(String url){
Serial.println(host);
Serial.println(url);
http.begin(host,port,url);
int httpCode = http.GET();
if (httpCode) {
if (httpCode == 200) {
Serial.println("API response ");
Serial.println(payload);
http.end();
