I need to find out the mac address of the router with the ESP8266
I have the IP with this command:
Serial.println(WiFi.gatewayIP());I also used a function to check all the devices connected to the ESP8266
void client_status() {
unsigned char number_client;
struct station_info *stat_info;
struct ip_addr *IPaddress;
IPAddress address;
int i=1;
number_client= wifi_softap_get_station_num();
stat_info = wifi_softap_get_station_info();
Serial.print(" Total Connected Clients are = ");
Serial.println(number_client);
while (stat_info != NULL) {
IPaddress = &stat_info->ip;
address = IPaddress->addr;
Serial.print("client= ");
Serial.print(i);
Serial.print(" IP adress is = ");
Serial.print((address));
Serial.print(" with MAC adress is = ");
Serial.print(stat_info->bssid[0],HEX);Serial.print(" ");
Serial.print(stat_info->bssid[1],HEX);Serial.print(" ");
Serial.print(stat_info->bssid[2],HEX);Serial.print(" ");
Serial.print(stat_info->bssid[3],HEX);Serial.print(" ");
Serial.print(stat_info->bssid[4],HEX);Serial.print(" ");
Serial.print(stat_info->bssid[5],HEX);Serial.print(" ");
stat_info = STAILQ_NEXT(stat_info, next);
i++;
}but I didn't manage to get the mac address of the router
is there any way?
