By hdwinkel
#75670 Hi,
I've a small problem: If I let run my sketch (I use the Arduino dev-environment) with an UART actively connected then the sketch runs perfectly. But if I let run the sketch without UART connected then it doesn't work. The flashing process isn't the problem, it works.
I have no idea what the problem can principally come from; an initializing problem or an electronically problem e.g. wrong resistors
The ESP8266-01 acts as a controller for a telephone dial and trigger an http event with the number was called.
I've tested it in two different variants with both the same broblem:
- use RX as switch (the pin0+2 as output)
- use the pin0+2 in combination as switch (pin0 set high/low on pin2)
see Waehlscheibe-variants in:
https://github.com/hdwinkel/ESP8266
Any idea?
