But I need more context to be of more help.
Explore... Chat... Share...
theenggprojects wrote:I can't say its the best way but i think its also a way, you can pull up all your pins and then can read their data, if any sensor is attached to any pin then its data will change and you can know that this pin has sensor attached to it. I hope it will work for you.
