By Stewart
#77471 I'm testing this project https://www.instructables.com/id/ESP8266-GMail-Sender/ and it operates as expected.
My only problem is, when sending SMS messages to a cell phone the HTML message displays with a box that must be clicked to display the text message.
So I'm simply trying to format the message as text instead of HTML.
This is the code containing the message formatting code.
Code: Select all#include "Gsender.h"
Gsender* Gsender::_instance = 0;
Gsender::Gsender(){}
Gsender* Gsender::Instance()
    if (_instance == 0)
        _instance = new Gsender;
    return _instance;
Gsender* Gsender::Subject(const char* subject)
  delete [] _subject;
  _subject = new char[strlen(subject)+1];
  strcpy(_subject, subject);
  return _instance;
Gsender* Gsender::Subject(const String &subject)
  return Subject(subject.c_str());
bool Gsender::AwaitSMTPResponse(WiFiClientSecure &client, const String &resp, uint16_t timeOut)
  uint32_t ts = millis();
  while (!client.available())
    if(millis() > (ts + timeOut)) {
      _error = "SMTP Response TIMEOUT!";
      return false;
  _serverResponce = client.readStringUntil('\n');
#if defined(GS_SERIAL_LOG_1) || defined(GS_SERIAL_LOG_2)
  Serial.println(_serverResponce);
#endif
  if (resp && _serverResponce.indexOf(resp) == -1) return false;
  return true;
String Gsender::getLastResponce()
  return _serverResponce;
const char* Gsender::getError()
  return _error;
bool Gsender::Send(const String &to, const String &message)
  WiFiClientSecure client;
#if defined(GS_SERIAL_LOG_2)
  Serial.print("Connecting to :");
  Serial.println(SMTP_SERVER);
#endif
  if(!client.connect(SMTP_SERVER, SMTP_PORT)) {
    _error = "Could not connect to mail server";
    return false;
  if(!AwaitSMTPResponse(client, "220")) {
    _error = "Connection Error";
    return false;
  Serial.println("HELO friend:");
#endif
  client.println("HELO friend");
  if(!AwaitSMTPResponse(client, "250")){
    _error = "identification error";
    return false;
  Serial.println("AUTH LOGIN:");
#endif
  client.println("AUTH LOGIN");
  AwaitSMTPResponse(client);
  Serial.println("EMAILBASE64_LOGIN:");
#endif
  client.println(EMAILBASE64_LOGIN);
  Serial.println("EMAILBASE64_PASSWORD:");
#endif
  client.println(EMAILBASE64_PASSWORD);
  if (!AwaitSMTPResponse(client, "235")) {
    _error = "SMTP AUTH error";
    return false;
  String mailFrom = "MAIL FROM: <" + String(FROM) + '>';
  Serial.println(mailFrom);
#endif
  client.println(mailFrom);
  String rcpt = "RCPT TO: <" + to + '>';
  Serial.println(rcpt);
#endif
  client.println(rcpt);
  Serial.println("DATA:");
#endif
  client.println("DATA");
  if(!AwaitSMTPResponse(client, "354")) {
    _error = "SMTP DATA error";
    return false;
  client.println("From: <" + String(FROM) + '>');
  client.println("To: <" + to + '>');
  client.print("Subject: ");
  client.println(_subject);
  client.println("Mime-Version: 1.0");
// original  client.println("Content-Type: text/html; charset=\"UTF-8\"");
  client.println("Content-Type: text/plain; charset=\"");
  client.println("Content-Transfer-Encoding: 7bit");
  client.println();
  String body = message; // "<!DOCTYPE html><html lang=\"en\">" + message + "</html>";
  client.println(body);
  client.println(".");
  if (!AwaitSMTPResponse(client, "250")) {
    _error = "Sending message error";
    return false;
  client.println("QUIT");
  if (!AwaitSMTPResponse(client, "221")) {
    _error = "SMTP QUIT error";
    return false;
  return true;
Changing this line:
Code: Select allString body = "<!DOCTYPE html><html lang=\"en\">" + message + "</html>";
To:
Code: Select allString body = message; // "<!DOCTYPE html><html lang=\"en\">" + message + "</html>";
And this mod, prevented email from sending,
Code: Select all// original  client.println("Content-Type: text/html; charset=\"UTF-8\"");
Makes no difference.
Any advice appreciated.
By Stewart
#77474 I have determined that this code is sending a text email message, but for some reason its not being received by my cell phone, as was the HTML version. Is delivered to other test email addresses.
I'm sending it as MMS as that is what the Cricket wireless gateway accepts.
