https://www.espressif.com/sites/default ... nes_en.pdf
My question is simple, what will be the consequences of routing and components underneath the antenna area (on the other side)?
Tks
Explore... Chat... Share...
schufti wrote:bad a) EMI and/or b) WiFi
depending on which signals you route close to the antenna, sensors and other evices will probably give false readings (enough examples in div threads) or (if it is control lines) you may experience erratic behaviour of the system.
For WiFi: as the antenna is also receiving (weak) signals from your AP, fast signals with steep edges can signifficantly disturb reception.
