#define sensor D0
int state = 0;
void setup()
Serial.begin(9600);
pinMode(sensor, INPUT_PULLUP);
void loop()
state=digitalRead(sensor);
if(state==LOW)
Serial.println("open");
else if(state==HIGH)
Serial.println("close");
when i run it, the serial print show "close". when i put the magnet close to the reed, the serial print"open".but when i put out the magnet from the reed, the serial print still show "open". then i modify the code to this:
#define sensor D0
int state = 0;
void setup()
Serial.begin(9600);
void loop()
if(state==HIGH)
else if(state==LOW)
when i run it, the serial print show "open" then i put the magnet close to the reed and the serial print show "close". but when i put out the magnet from the reed, the serial print still show "close".
i found that my code is stuck at (state==LOW)
anyone know how to fix it?
