I want to add alarm motion detector to these codes, how can I do it? and I want to make the alarm active or passive with 1 button
I use the device esp8266 nodemcu
What I need to add to this code, I want to compile both the relay control and the alarm system, I would be very glad if you help. I want to activate or deactivate the alarm with a button
RELAY KONTROL CODE
// esp librari
// kablosuz ağ ayarları
const char* ssid = "okhan"; //ağ adı
const char* password = "atakan2009"; // parola
// server protum
WiFiServer server(80);
// http istekleri
String header;
// röle duurumu
String relay1State = "kapat";
String relay2State = "kapat";
String relay3State = "kapat";
String relay4State = "kapat";
// röle pinleri
const int relay1 = 5; // GPIO5 D1 nodemcu karşılıkları
const int relay2 = 4; // GPIO4 D2
const int relay3 = 0; // GPIO0 D3
const int relay4 = 2; // GPIO2 D4
// pinlerin durumu giriş/çıkış
pinMode(relay1, OUTPUT);
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
// çıkış ayaları
digitalWrite(relay1, HIGH);
digitalWrite(relay2, HIGH);
digitalWrite(relay3, HIGH);
digitalWrite(relay4, HIGH);
// hadi ağa bağlanalım
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// espnin ip adresini yazdıralım
Serial.println("");
Serial.println("Kablosuz Bağlandı.");
Serial.println("Sunucu Ip Adresi: ");
server.begin();
WiFiClient client = server.available(); // sisteme bağlı cihaz sayısı
if (client) { // yeni bağlantı
Serial.println("Yeni Veri."); // seri porttan okuyalım
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
// turns the GPIOs on and off
if (header.indexOf("GET /5/ac") >= 0)
Serial.println("GPIO 5 ac");
relay1State = "ac";
digitalWrite(relay1, LOW);
else if (header.indexOf("GET /5/kapat") >= 0)
Serial.println("GPIO 5 kapat");
else if (header.indexOf("GET /4/ac") >= 0) {
Serial.println("GPIO 4 ac");
relay2State = "ac";
digitalWrite(relay2, LOW);
else if (header.indexOf("GET /4/kapat") >= 0) {
Serial.println("GPIO 4 kapat");
else if (header.indexOf("GET /0/ac") >= 0)
Serial.println("GPIO 0 ac");
relay3State = "ac";
digitalWrite(relay3, LOW);
else if (header.indexOf("GET /0/kapat") >= 0)
Serial.println("GPIO 0 kapat");
else if (header.indexOf("GET /2/ac") >= 0) {
Serial.println("GPIO 2 ac");
relay4State = "ac";
digitalWrite(relay4, LOW);
else if (header.indexOf("GET /2/kapat") >= 0) {
Serial.println("GPIO 2 kapat");
// Display the HTML web page
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
// CSS to style the on/off buttons
// Feel free to change the background-color and font-size attributes to fit your preferences
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #195B6A; border: none; color: white; padding: 12px 24px;");
client.println("text-decoration: none; font-size: 20px; margin: 2px; cursor: pointer;}");
client.println(".button2 {background-color: #77878A;}</style></head>");
// Web Page Heading
client.println("<body><h1>Evoto Ev Kontrol Sistemi</h1>");
// Display current state, and ON/OFF buttons for GPIO 5
client.println("<p>Buton 1 Durumu " + relay1State + "</p>");
// If the relay1State is off, it displays the ON button
if (relay1State == "kapat") {
client.println("<p><a href=\"/5/ac\"><button class=\"button\">Aktif</button></a></p>");
} else {
client.println("<p><a href=\"/5/kapat\"><button class=\"button button2\">Pasif</button></a></p>");
// Display current state, and ON/OFF buttons for GPIO 4
client.println("<p>Buton 2 Durumu " + relay2State + "</p>");
// If the relay2State is off, it displays the ON button
if (relay2State == "kapat") {
client.println("<p><a href=\"/4/ac\"><button class=\"button\">Aktif</button></a></p>");
} else {
client.println("<p><a href=\"/4/kapat\"><button class=\"button button2\">Pasif</button></a></p>");
// Display current state, and ON/OFF buttons for GPIO 0
client.println("<p>Buton 3 Durumu " + relay3State + "</p>");
if (relay3State == "kapat") {
client.println("<p><a href=\"/0/ac\"><button class=\"button\">Aktif</button></a></p>");
} else {
client.println("<p><a href=\"/0/kapat\"><button class=\"button button2\">Pasif</button></a></p>");
// Display current state, and ON/OFF buttons for GPIO 2
client.println("<p>Buton 4 Durumu " + relay4State + "</p>");
if (relay4State == "kapat") {
client.println("<p><a href=\"/2/ac\"><button class=\"button\">Aktif</button></a></p>");
} else {
client.println("<p><a href=\"/2/kapat\"><button class=\"button button2\">Pasif</button></a></p>");
client.println("</body></html>");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
break;
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Sunucu Kapandı.");
Serial.println("");
}motion dedektor code
int Status = 12;
int sensor = 13;
pinMode(sensor, INPUT); // declare sensor as input
pinMode(Status, OUTPUT); // declare LED as output
void loop(){
long state = digitalRead(sensor);
delay(1000);
if(state == HIGH){
digitalWrite (Status, HIGH);
Serial.println("Motion detected!");
else {
digitalWrite (Status, LOW);
Serial.println("Motion absent!");
i want this codes, merge, and add alarm on/off button
