By Sirquil
#79214 Library example:
Code: Select all#ifdef ESP8266
#elif defined ESP32
#include <WiFi.h>
#include "SPIFFS.h"
#endif
#include <ESP8266FtpServer.h>
const char* ssid = "YourSSID";
const char* password = "YourPassword;
FtpServer ftpSrv;   //set #define FTP_DEBUG in ESP8266FtpServer.h to see ftp verbose on serial
void setup(void){
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.println(ssid);
  Serial.print("IP address: ");
  /////FTP Setup, ensure SPIFFS is started before ftp;  /////////
#ifdef ESP32       //esp32 we send true to format spiffs if cannot mount
  if (SPIFFS.begin(true)) {
#elif defined ESP8266
  if (SPIFFS.begin()) {
#endif
      Serial.println("SPIFFS opened!");
      ftpSrv.begin("esp8266","esp8266");    //username, password for ftp.  set ports in ESP8266FtpServer.h  (default 21, 50009 for PASV)
void loop(void){
  ftpSrv.handleFTP();        //make sure in loop you call handleFTP()!!
 // server.handleClient();   //example if running a webserver you still need to call .handleClient();
I have Windows 10 Fall 2018 update with Filezilla 64 bit client installed. I am running Norton Security from Comcast version 22.15.0.88 and no matter what I try I get "Connection attempt failed with "ETIMEDOUT - Connection attempt timed out" Even after adjusting timeout value.
Arduino IDE 1.8.7 and esp8266 core 2.4.2 installed.
Ports for FTP are forwarded at router and have application allowed in Norton; plus I have added firewall rule for FTP ports. Stii does not work for me...
William
