Problem is that it does not send any data if pressed once. Instead we have to keep remote key pressed to transmit key code. This creates a burst of continuous data for that key in format #AAAA:01.
Now my problem is I want to interface this remote to ESP8266 and toggle a http resource. I understand this very typical setup, but i need it this way. My problem is how to detect multiple same key as one event on serial so that if it happens again I can achieve the toggle action.
So in short i want to toggle a resource upon pressing switch on remote.
Hardware setup is simple: Ive attached 433Mhx receiver modules TX pin to ESP8266's D13 and using SoftwareSerial to read data. Currently I get :
#AAAA:01#AAAA:01#AAAA:01#AAAA:01#AAAA:01#AAAA:01#AAAA:01#AAAA:01#AAAA:01#AAAA:01I want it only to detect as one #AAAA:01 but if pressed again after few seconds its second #AAAA:01 with which we can toggle some variable.
code is simple.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 14, false, 256);//RX, TX
String readString; //main captured String
int buttonState = LOW; //this variable tracks the state of the button, low if not pressed, high if pressed
int ledState = 0; //this variable tracks the state of the LED, negative if off, positive if on
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 10; // the debounce time; increase if the output flickers
const byte interruptPin = 13;
pinMode(interruptPin, INPUT_PULLUP);
Serial.begin(9600);
mySerial.begin(9600);
if (mySerial.available()) {
char c = mySerial.read(); //gets one byte from serial buffer
if (c == '#') {
//do stuff
int ind1 = readString.indexOf(':');
String id = readString.substring(0, ind1);
String key = readString.substring(ind1 + 1);
Serial.println(id);
if (id == "AAAA") {
Serial.println(millis());
if ((millis() - lastDebounceTime) > 50 ) {
//lastDebounceTime = millis();
Serial.println("key Pressed: ");
Serial.println(key);
readString = ""; //clears variable for new input
id = "";
key = "";
else {
readString += c; //makes the string readString
}I tried debauching like code with millis() but it did not work.
