Hi I have an ESP8266 NodemCu - when I upload the file json + sketch it does it perfectly, but in the Serial Monitor I get the following legend "ets Jan 8 2013, rst cause: 2, boot mode: (3,7) ets_main.c "If you can help me. thank you very much, greetings
Este es el código
// Example: storing JSON configuration file in flash file system
// Uses ArduinoJson library by Benoit Blanchon.
// https://github.com/bblanchon/ArduinoJson
// Created Aug 10, 2015 by Ivan Grokhotkov.
// This example code is in the public domain.
#include <ArduinoJson.h>
#include "FS.h"
bool loadConfig() {
File configFile = SPIFFS.open("/config.json", "r");
if (!configFile) {
Serial.println("Failed to open config file");
return false;
size_t size = configFile.size();
if (size > 1024) {
Serial.println("Config file size is too large");
return false;
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
// We don't use String here because ArduinoJson library requires the input
// buffer to be mutable. If you don't use ArduinoJson, you may as well
// use configFile.readString instead.
configFile.readBytes(buf.get(), size);
StaticJsonBuffer<200> jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
if (!json.success()) {
Serial.println("Failed to parse config file");
return false;
const char* serverName = json["serverName"];
const char* accessToken = json["accessToken"];
// Real world application would store these values in some variables for
// later use.
Serial.print("Loaded serverName: ");
Serial.println(serverName);
Serial.print("Loaded accessToken: ");
Serial.println(accessToken);
return true;
bool saveConfig() {
JsonObject& json = jsonBuffer.createObject();
json["serverName"] = "api.example.com";
json["accessToken"] = "128du9as8du12eoue8da98h123ueh9h98";
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("Failed to open config file for writing");
return false;
json.printTo(configFile);
return true;
Serial.begin(9600);
Serial.println("");
delay(1000);
Serial.println("Mounting FS...");
if (!SPIFFS.begin()) {
Serial.println("Failed to mount file system");
return;
// if (!saveConfig()) {
// Serial.println("Failed to save config");
//} else {
//Serial.println("Config saved");
if (!loadConfig()) {
//Serial.println("Failed to load config");
} else {
//Serial.println("Config loaded");
