I'm building a Alarmclock With a ESP8266 / TM1637 display
Everything works but i cant connect with the HTML Page .
I Get a IP Adress, Wifi works fine so i get the internet time but when i type the IP Address
I see in debug failures sse below.
I'm not a good programmer so help me please i spend so many hours on this.
The sketch i have is form https://diyodemag.com/projects/morning_has_broken
I ask there but no response for my problem.
I looks like when the server get a signal he disabled or something.
I don't know where i have to search, is this ESP8266webserver or is this ArduinoJson
I placed the code and the debug
I hope someone can help me, sorry for my bad english i'm Dutch
Leo
//github V019. Code cleanup and hardware prep.
#include <ArduinoJson.h>
#include <WiFiUdp.h>
#include <ESP8266WebServer.h>
IPAddress ip(192, 168, 178, 66); // choose IP address
IPAddress subnet(255, 255, 255, 0);
ESP8266WebServer server(80);
const char* ssid = "EHCO.nl";
const char* pass = "Draadloos1";
int lampState = 0;
int alarmSet = 0;
int alarmHour = 6;
int alarmMin = 0;
int timezone = +1; //make 11 for Daylight saving. +10 for sydney etc
unsigned int localPort = 2390;// local port to listen for UDP packets
IPAddress timeServerIP; // time.nist.gov NTP server address
const char* ntpServerName = "nl.pool.ntp.org";
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
WiFiUDP udp;
//Neopixel Setup
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN D3 //Pin D8 on the Wemos
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 16 //8 if only useing one strip, 16 for 2
#define BRIGHTNESS 255
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
//Clock Setup
#include "TM1637.h"
//Pins for TM1637
#define CLK D7//8
#define DIO D6//was9
TM1637 tm1637(CLK, DIO);
int hh, mm;
int decPoint = 0;
//Alarms Setup
#include <TimeLib.h>
#include <TimeAlarms.h>
//Pins setup
int resetButton = D5;
int piezoPin = D8;
int buzzerOn = 0;
//Chase function, used in partyMode
static void chase(uint32_t c) {
for (uint16_t i = 0; i < pixels.numPixels() + 4; i++) {
pixels.setPixelColor(i, c); // Draw new pixel
pixels.setPixelColor(i - 4, 0); // Erase pixel a few steps back
pixels.show();
delay(25);
//Demo to test all the pixels are working. Will loop until the reset button is held down
void partyMode() {
Serial.println("Party Mode Active");
while (digitalRead(resetButton) == LOW) {
//set clock
//we're gunna party like it's;
tm1637.point(POINT_OFF);
tm1637.display(0, 1);
tm1637.display(1, 9);
tm1637.display(2, 9);
tm1637.display(3, 9);
chase(pixels.Color(255, 0, 0)); // Red
chase(pixels.Color(0, 255, 0)); // Green
chase(pixels.Color(0, 0, 255)); // Blue
void lightOn() {
for (int i = 0; i < NUMPIXELS; i++) {
pixels.setPixelColor(i, pixels.Color(255, 255, 255));
//Serial.println(i);
pixels.show();
lampState = 1;
Serial.print("Lamp State: ");
Serial.println(lampState);
void lightOff() {
pixels.setPixelColor(i, pixels.Color(0, 0, 0));
pixels.show();
lampState = 0;
void setPink() {
Serial.println("System OK");
pixels.setPixelColor(i, pixels.Color(255, 20, 20));
pixels.show();
void setRed() {
Serial.println("Set to RED, 60 minutes");
pixels.setPixelColor(i, pixels.Color(255, 0, 0));
pixels.show();
void setBlue() {
pixels.setPixelColor(i, pixels.Color(0, 0, 255)); // Moderately bright green color. //20
pixels.show(); // This sends the updated pixel color to the hardware.
void setGreen() {
pixels.setPixelColor(i, pixels.Color(0, 255, 0)); // Moderately bright green color. //20
void set1() {//10
pixels.setPixelColor(i, pixels.Color(255, 5, 0));
pixels.show();
void set2() {//20
pixels.setBrightness(100);
pixels.setPixelColor(i, pixels.Color(255, 10, 0));
pixels.show();
void set3() {//30
pixels.setBrightness(200);
pixels.setPixelColor(i, pixels.Color(255, 128, 0));
pixels.show();
void set4() {//40
pixels.setBrightness(BRIGHTNESS);
Serial.println("Wake up");
buzzerOn = 1;
pixels.show();
void setClockDisplay() {
if (decPoint == 0) {
decPoint = 1;
} else {
tm1637.point(POINT_ON);
decPoint = 0;
tm1637.display(0, hh / 10); // hour
tm1637.display(1, hh % 10);
tm1637.display(2, mm / 10); // minutes
tm1637.display(3, mm % 10);
void showIP() {
// IPAddress ip = WiFi.localIP();
// char buf[16];
// buf
////sprintf(lcdBuffer, "%d.%d.%d.%d:%d", ip[0], ip[1], ip[2], ip[3], udpPort);
// Serial.println(WiFi.localIP());
// tm1637.display(0, hh / 10); // hour
// tm1637.display(1, hh % 10);
// tm1637.display(2, mm / 10); // minutes
// tm1637.display(3, mm % 10);
// delay(500);
unsigned long sendNTPpacket(IPAddress& address) {
Serial.println("sending NTP packet...");
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
udp.beginPacket(address, 123); //NTP requests are to port 123
udp.write(packetBuffer, NTP_PACKET_SIZE);
udp.endPacket();
void getTime() {
//get a random server from the pool
WiFi.hostByName(ntpServerName, timeServerIP);
sendNTPpacket(timeServerIP); // send an NTP packet to a time server
// wait to see if a reply is available
delay(1000);
int cb = udp.parsePacket();
if (!cb) {
Serial.println("no packet yet");
else {
Serial.print("packet received, length=");
Serial.println(cb);
// We've received a packet, read the data from it
udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, esxtract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
Serial.print("Seconds since Jan 1 1900 = " );
Serial.println(secsSince1900);
// now convert NTP time into everyday time:
Serial.print("Unix time = ");
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
// subtract seventy years:
unsigned long epoch = secsSince1900 - seventyYears;
// print Unix time:
Serial.println(epoch);
//utc offset...
//set this bit and ntp
//setTime(8,29,0,1,1,11); // set time to Saturday 8:29:00am Jan 1 2011
epoch = epoch + (3600 * timezone); //sets the UTC timezone offset
int cHour = ((epoch % 86400L) / 3600);
int cMin = ((epoch % 3600) / 60);
int cSec = (epoch % 60);
setTime(cHour, cMin, cSec, 1, 1, 11);
//adjusttime
// print the hour, minute and second:
Serial.print("The UTC time is "); // UTC is the time at Greenwich Meridian (GMT)
Serial.print((epoch % 86400L) / 3600);// print the hour (86400 equals secs per day)
Serial.print(':');
if ( ((epoch % 3600) / 60) < 10 ) {
// In the first 10 minutes of each hour, we'll want a leading '0'
Serial.print('0');
Serial.print((epoch % 3600) / 60);// print the minute (3600 equals secs per minute)
Serial.print(':');
if ( (epoch % 60) < 10 ) {
// In the first 10 seconds of each minute, we'll want a leading '0'
Serial.print('0');
Serial.println(epoch % 60); // print the second
void handleStatus() {
String message;
message += "{ \"lampOn\": ";
message += lampState;
message += ", ";
message += "\"alarmSet\": ";
message += alarmSet;
message += ", ";
message += "\"alarmHour\": ";
message += alarmHour;
message += ", ";
message += "\"alarmMin\": ";
message += alarmMin;
message += " }";
server.send(200, "text/plain", message );
void handleLamp() {
//im the client.
StaticJsonBuffer<200> jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(server.arg("plain"));
root.printTo(Serial);
int lampStatus = root["lampOn"];
if (lampStatus == 0) {
lightOff();
} else {
lightOn();
String message;
message += "{ \"success\": ";
message += "1 }";
void handleSet() {
//int lampStatus = root["lampOn"];
alarmHour = root["alarmHour"];
alarmMin = root["alarmMin"];
setAlarm();
String message;
message += "1 }";
void Repeats() {
Serial.println("15 second timer");
void setAlarm() {
//Set the alarms
Serial.println("Alarms set");//message +=alarmHour;
//final time alarm
Alarm.alarmOnce(alarmHour - 2, alarmMin, 0, set2);
Alarm.alarmOnce(alarmHour - 1, alarmMin, 0, set3);
Alarm.alarmOnce(alarmHour, alarmMin, 0, set4);
Serial.print ("Alarm Set for: ");
Serial.print(alarmHour);
Serial.print(":");
Serial.println(alarmMin);
alarmSet = 1;
//?6
pixels.begin(); // This initializes the NeoPixel library.
pinMode(piezoPin, OUTPUT);
tm1637.init();
tm1637.set(5);//BRIGHT_TYPICAL = 2,BRIGHT_DARKEST = 0,BRIGHTEST = 7;
Serial.println(ssid);
WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("Starting UDP");
udp.begin(localPort);
Serial.print("Local port: ");
Serial.println(udp.localPort());
pinMode(resetButton, INPUT);
//server
server.on("/status", handleStatus);
server.on("/lamp", handleLamp);
server.on("/set", handleSet);
server.begin(); //Start the server
//gettime
lightOff();
getTime();
//party mode. enter test circuit. Once you have started, press the rest button to revert to noprmal mode
partyMode();
void digitalClockDisplay() {
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
void printDigits(int digits) {
Serial.print(":");
if (digits < 10)
Serial.print('0');
Serial.print(digits);
hh = hour(), DEC;
mm = minute(), DEC;
if (buzzerOn == 1) {
digitalWrite(piezoPin, HIGH);
delay(100);
digitalWrite(piezoPin, LOW);
//flash lights? This is where you add flash code or call a function to do so
} else {
//Display Clock
setClockDisplay();
//Alarm.delay(1);
if (digitalRead(resetButton) == HIGH) {
setBlue();
buzzerOn = 0;
lightOff();
//getTime();//ntp server
//Serial.println(WiFi.localIP());
Alarm.delay(1);
server.handleClient();
delay(100);
}//github V019. Code cleanup and hardware prep.
int lampState = 0;
int alarmSet = 0;
int alarmHour = 6;
int alarmMin = 0;
WiFiUDP udp;
//Neopixel Setup
#ifdef __AVR__
#endif
//Clock Setup
#include "TM1637.h"
//Pins for TM1637
#define CLK D7//8
int hh, mm;
int decPoint = 0;
//Alarms Setup
//Pins setup
int piezoPin = D8;
int buzzerOn = 0;
pixels.show();
delay(25);
void partyMode() {
//set clock
void lightOn() {
pixels.show();
lampState = 1;
void lightOff() {
pixels.show();
lampState = 0;
void setPink() {
pixels.show();
void setRed() {
pixels.show();
void setBlue() {
void setGreen() {
void set1() {//10
pixels.show();
void set2() {//20
pixels.show();
void set3() {//30
pixels.show();
void set4() {//40
buzzerOn = 1;
pixels.show();
decPoint = 1;
} else {
decPoint = 0;
void showIP() {
// char buf[16];
// buf
// delay(500);
udp.endPacket();
void getTime() {
delay(1000);
if (!cb) {
else {
Serial.println(cb);
// print Unix time:
//utc offset...
//adjusttime
Serial.print(':');
Serial.print('0');
Serial.print(':');
Serial.print('0');
String message;
message += ", ";
message += ", ";
message += ", ";
message += " }";
void handleLamp() {
//im the client.
lightOff();
} else {
lightOn();
String message;
message += "1 }";
void handleSet() {
setAlarm();
String message;
message += "1 }";
void Repeats() {
void setAlarm() {
//Set the alarms
//final time alarm
Serial.print(":");
alarmSet = 1;
//?6
tm1637.init();
Serial.print(".");
Serial.println("");
//server
//gettime
lightOff();
getTime();
partyMode();
Serial.print(":");
if (digits < 10)
Serial.print('0');
hh = hour(), DEC;
mm = minute(), DEC;
delay(100);
} else {
//Display Clock
setClockDisplay();
//Alarm.delay(1);
setBlue();
buzzerOn = 0;
lightOff();
Alarm.delay(1);
delay(100);
}DEBUG CODE
Connecting to EHCO.nl
sta config unchangedscandone
wifi evt: 2
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
connected with EHCO.nl, channel 13
dhcp client start...
wifi evt: 0
.ip:192.168.178.66,mask:255.255.255.0,gw:192.168.178.1
wifi evt: 3
WiFi connected
IP address:
192.168.178.66
Starting UDP
Local port: 2390
Lamp State: 0
[hostByName] request IP for: nl.pool.ntp.org
[hostByName] Host: nl.pool.ntp.org IP: 131.211.8.244
:urn 48
packet received, length=48
:urd 48, 48, 0
Seconds since Jan 1 1900 = 3753295555
Unix time = 1544306755
The UTC time is 23:05:55
Party Mode Active
wifi evt: 7
*******The text under i get when i try to connect with the webpage******
WS:ac
:rn 373
:ref 1
WS:av
:ref 2
:ur 2
New client
:ref 2
:ur 2
method: GET url: /status search:
headerName: Host
headerValue: 192.168.178.66
headerName: Connection
headerValue: keep-alive
headerName: Accept
headerValue: application/json, text/javascript, */*; q=0.01
headerName: Origin
headerValue: null
headerName: User-Agent
headerValue: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/70.0.3538.110 Safari/537.36
headerName: Accept-Encoding
headerValue: gzip, deflate
headerName: Accept-Language
headerValue: nl-NL,nl;q=0.9,en-US;q=0.8,en;q=0.7,de;q=0.6,da;q=0.5
:c0 1, 373
args:
Request: /status
Arguments:
:wr 84 84 0
:wrc 84 84 0
:wr 61 61 0
:wrc 61 61 0
:ack 84
:ack 61
:rcl
:abort
:ur 1
WS:dis
:del
