Although a lot of (older) websites and instructables are using these modules, when you're new it's better to first play around with something like a NodeMCU (see my signature), which you luckilly also already have.
What you need to do first is make sure you've got the correct USB drivers installed on your PC for the used UART -> USB convertor that's on the NodeMCU: this can be either a CP2102 (a square IC next to the USB port) or a CH340 (a rectangular IC next to the USB port) chip.
When you've installed the correct driver (although it shouldn't hurt when installing both at once), you can connect the NodeMCU to a free USB-port (this may be USB 1 or 2, try to avoid a USB 3, blue coloured, port): you should hear the "External device found" chime from the OS and a notifying window.
Now go to device manager (just run "devmgmt.msc" from the start-menu) and under the "Ports (COM & LPT)" node, there should be an entry for a device called "USB-SERIAL CP2102" or "USB-SERIAL CH340" (or a name similar to that) followed by the designated COM-port: "COMxx": make a note of this COM-port number.
Download a good terminal program, like PuTTY and install it on your PC.
Start up PuTTY and create a connection with the following properties:
- Set the radio-button to "Serial"
- Set "Serial line" to the COM-port you just made a note of (eg. "COM15", without the quotes)
- Set the speed to 74880 Baud (yes really 74880, this is not a typo)
- Choose a name (for instance "ESP on COM 15") under "Saved Sessions" and press the "Save"-button
Now press the RESET-button on your NodeMCU and you should see a message like this:
tail 8
chksum 0x2d
csum 0x2d
v00000000
~ld
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒Good luck!
