By ulissesp
#79825 Good afternoon,
I'm having problems with a lot of ESP07 that I bought and would like some help.
I made a dedicated PCB with my circuit where I put the ESP07 and upload the skech with the Arduino IDE. Well, I bought some ESP07, I can upload the sketch on them, but ESP does nothing, It does not show anything on the serial monitor. Nor does the blink code work.
I have other ESP07 parts that I bought in China and they work normally.
Can anyone give me a hint of what it can be?
I already researched a lot on the net and found nothing.
The module with the Ai mark is what works.
Thank you.
By btidey
#79830 One possible cause of this type of behaviour is that you have a batch of modules with a different type of flash memory connection which need a different flash mode.
Normally QIO is used but some modules need DIO or DOUT for a flash to program the memory correctly.
However, this is just a guess. You need to give us more details like the schematic, the powering scheme, and the code you are trying to use.
By ulissesp
#79848
btidey wrote:One possible cause of this type of behaviour is that you have a batch of modules with a different type of flash memory connection which need a different flash mode.
Hi btidey,
Thank you for your help. Your guess was right, I changed to DOUT and worked.
Thanks again.
