I can post to Flow using apitester.com like so;
I've tried to replicate this with the ESP8266 but having problems.
I found the following example - https://github.com/esp8266/Arduino/issues/2834
Here i my code
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <ArduinoHttpClient.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
Serial.println("Attempting to connect to wifi");
WiFiManager wifiManager;
//wifiManager.resetSettings(); //reset saved settings
wifiManager.autoConnect("AutoConnectAP");
Serial.println("connected");
Serial.println("attempt POST");
HTTPClient http;
http.begin("https://prod-23.westeurope.logic.azure.com:443/workflows/4221219928b1479186337912abba9907/triggers/manual/paths/invoke?api-version=2016-06-01&sp=%2Ftriggers%2Fmanual%2Frun&sv=1.0&sig=FxDTZGTHI1iF784ILXLXM707U0TonG_j_xxxxxxxxxxx");
http.addHeader("Content-Type", "application/json");
String postMessage = "{'temp':'21'}";
int httpCode = http.POST(postMessage);
Serial.print("http result:");
Serial.println(httpCode);
http.writeToStream(&Serial);
http.end();
delay(5000); //Post Data at every 5 seconds
}my only output is;
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 3
*WM: IP Address:
*WM: 192.168.43.166
connected
*WM: freeing allocated params!
attempt POST
http result:-1
