GPIO out help
Posted: Fri Mar 06, 2015 9:58 am
Hello friends
Please help with GPIO outputs seeks to add 4 GPIO outputs to control ws2812 pixels me managed to add outputs GPIO0 and GPOI2 is working properly but I would need to add additional 2 outputs GPIO13 and GPIO14 please can someone advise how to do it thanks.
here is the code
#include "osapi.h"
#include "ets_sys.h"
#define GPIO_OUTPUT_SET(gpio_no, bit_value) gpio_output_set(bit_value<<gpio_no, ((~bit_value))<<gpio_no, 1<<gpio_no,0)
void ICACHE_FLASH_ATTR SEND_WS_0()
uint8_t time;
time = 4; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR , 0x1 );
time = 9; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR , 0 );
void ICACHE_FLASH_ATTR SEND_WS_1()
uint8_t time;
time = 8; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR , 0x1 );
time = 6; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR , 0 );
void ICACHE_FLASH_ATTR SEND_WS_2()
uint8_t time;
time = 4; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR , 0x4 );
void ICACHE_FLASH_ATTR SEND_WS_3()
uint8_t time;
time = 8; while(time--) WRITE_PERI_REG( PERIPHS_GPIO_BASEADDR , 0x4 );
void ICACHE_FLASH_ATTR ws2812_strip1(uint8_t * buffer, uint16_t length)
uint16_t i;
GPIO_OUTPUT_SET(GPIO_ID_PIN(0), 0);
os_intr_lock();
for( i = 0; i < length; i++ )
uint8_t mask = 0x80;
uint8_t byte = buffer[i];
while (mask)
( byte & mask ) ? SEND_WS_1() : SEND_WS_0();
mask >>= 1;
os_intr_unlock();
void ICACHE_FLASH_ATTR ws2812_strip2(uint8_t * buffer, uint16_t length)
uint16_t i;
GPIO_OUTPUT_SET(GPIO_ID_PIN(2), 0);
os_intr_lock();
while (mask)
( byte & mask ) ? SEND_WS_3() : SEND_WS_2();
mask >>= 1;
os_intr_unlock();
void ICACHE_FLASH_ATTR ws2812_init()
ets_wdt_disable();
char outbuffer[] = { 0x00, 0x00, 0x00 };
ws2812_strip1( outbuffer, sizeof(outbuffer) );
ws2812_strip2( outbuffer, sizeof(outbuffer) );
here is the code
#include "osapi.h"
uint8_t time;
uint8_t time;
uint8_t time;
uint8_t time;
uint16_t i;
os_intr_lock();
while (mask)
mask >>= 1;
os_intr_unlock();
uint16_t i;
os_intr_lock();
while (mask)
mask >>= 1;
os_intr_unlock();
ets_wdt_disable();
