But what if my router is down, for any reason, and the ESP cannot connect to WiFi?
I suppose it gets stuck at ' if(!wifiManager.autoConnect', right?
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
WiFiManager wifiManager;
wifiManager.setTimeout(180);
//and goes into a blocking loop awaiting configuration
if(!wifiManager.autoConnect("AutoConnectAP")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
What I want is this:
-at setup, try to connect to wifi
-if succeeds ok no problem If fails, again no problem, BUT don't get stucked here, continue to main loop and.
-while at main loop, try at sometime to reconnect to wifi
I 've been told that the solution is 'setConfigPortalTimeout'.
But nothing more.
So, how can I make it work the way I want with the 'setConfigPortalTimeout'?
