I am using Wifimanager for wifi setup in my projects and as usual it presented the captive portal for wifi credentials and works fine.The issue I face is if for some reason there is a Wifi disconnection(powerfail) it usually enters after certain time into captiveportal/access point state where I need to restart the ESP8266 to make it connect to earlier saved WiFi information once the WiFi is back else it will simply remain in access point mode/captive portal state, I wanted a way if possible to continuously try after certain time for saved Wifi connection information
