My problem is when I tried using the function stream() from arduino firebase library and check firebase.available() to see if there is any change, it always return true even though nothing is changed in the database, here is the code
#include <ArduinoJson.h>
#include <Firebase.h>
#include <FirebaseArduino.h>
#define FIREBASE_HOST "xxxxxxxx"
#define FIREBASE_AUTH "xxxxxxxx"
#define WIFI_SSID "xxxxxx"
#define WIFI_PASSWORD "xxxxxx"
#define LED1 14
pinMode(LED1, OUTPUT);
digitalWrite(LED1, 0);
Serial.begin(9600);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("connecting");
Serial.print(".");
Serial.print("connected: ");
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
Firebase.stream("LED1");
if (Firebase.available()) {
Serial.println("Action!");
if (Firebase.failed()) // Check for errors
Serial.print("setting /number failed:");
Serial.println(Firebase.error());
return;
delay(10);
