By scsi050
#83510 I have an ESP-07 that doesn't seem to want to boot into normal mode. It programs fine, I reboot it into normal mode and the boot log looks fine, but after that it doesn't do anything. I've programmed testing with the AT firmware and the latest micropython firmware and both have the same results....nothing. AT just sits there and doesn't give me any echo feedback for my AT commands. Micropython doesn't broadcast as a wifi access point as it should on boot. It's like it "boots" but doesn't know to start any scripts. Any suggestions? thanks
vcc: 3.3
CH_PD: 3.3
RESET: 3.3
GND: GND
GPIO15: GND
GPIO2: 3.3
GPIO0: 1.8v during normal boot, GND during program mode
Tx: RX
RX: TX
programming works fine...
Code: Select allxx@xx:~ $ esptool.py --chip auto --port /dev/ttyAMA0 --baud 57600 write_flash --flash_size=detect -fm qio 0 esp8266-micropython.-v1.11.bin
esptool.py v2.6
Serial port /dev/ttyAMA0
Connecting.....
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
MAC: 84:f3:eb:ba:e3:6e
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 1MB
Flash params set to 0x0020
Compressed 617880 bytes to 402086...
Wrote 617880 bytes (402086 compressed) at 0x00000000 in 72.9 seconds (effective 67.8 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
Booting into normal mode, the boot log looks good.
Code: Select allxx@xx:~ $ miniterm.py /dev/ttyAMA0 74880
--- Miniterm on /dev/ttyAMA0  74880,8,N,1 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
 ets Jan  8 2013,rst cause:2, boot mode:(3,0)
load 0x40100000, len 31024, room 16
tail 0
chksum 0xef
load 0x00000000, len 0, room 8
tail 0
chksum 0xef
load 0x00000000, len 0, room 0
tail 0
chksum 0xef
csum 0xef
csum err
ets_main.c
