Can I safetly power the node mcu from an external 3.3V source and at the same time connect the usb?
Explore... Chat... Share...
Power to the NodeMCU v2 is supplied via the on-board USB Micro B connector or directly via the “VIN” pin. The power source is selected automatically.
