By Sirquil
#84236 Existing code in WiFi client/server:
Code: Select all                         if (strcmp(path, "/SdBrowse") == 0)   // Respond with the path that was accessed.
                              // send a standard http response header
                              client.println("HTTP/1.1 200 OK");
                              client.println("Content-Type: text/html");
                              client.println();
                              client.println("<!DOCTYPE HTML>");
                              client.println("<html>");
                              client.println("<body>");
                              client.println("<head><title>SDBrowse</title></head>");
                              // print all the files, use a helper to keep it clean
                              client.println("<h2>Collected Observations<br><br>");
                              String str;
                              if (!SPIFFS.begin(true))
                                   Serial.println("An Error has occurred while mounting SPIFFS");
                                   return;
                              File root = SPIFFS.open("/");
                              File file = root.openNextFile();
                              while (file)
                                   if(strncmp(file.name(), "/LOG", 4) == 0)
                                        str += "<a href=\"";
                                        str += file.name();
                                        str += "\">";
                                        str += file.name();
                                        str += "</a>";
                                        str += "    ";
                                        str += file.size();
                                        str += "<br>\r\n";
                              client.print(str);
                              client.println("<br><br>");
                              client.println("<a href=http://" + publicIP + ":" +  LISTEN_PORT + "/Weather    >Home</a><br>");
                              client.println("</body></h2>");
                              client.println("</html>");
                              end();
Original code by martinayotte, modified for ESP32.
Result in WiFi client/server:
Working HTML and code
Is there a way to combine HTML and code for Asyncwebserver? PHP code used with HTML?
William
By Sirquil
#84240 Solved!
Code: Select allHTML:
//index2.h
const char HTML2 PROGMEM[] = R"====(
<!DOCTYPE HTML>
<html>
<head>
    <meta http-equiv="refresh" content="15">
</head>
<body>
    <br>
    <br>%URLLINK%
    <br>
<body>
</html>
setup:
serverAsync.on("/SdBrowse", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send_P(200, PSTR("text/html"), HTML2, processor2);
processor function:
String processor2(const String& var)
    //index2.h
    String str;
       //return;
    while (file)
            str += file.name();
            str += "\">";
            str += file.name();
            str += "</a>";
            str += "    ";
            str += file.size();
            str += "<br>\r\n";
    if(var == F("URLLINK"))
      return  str;
    return String();
SdBrowse result:
SdBrowse result.JPG (34.52 KiB) Viewed 5736 times
William
By Pablo2048
#84245 William, I have some suggestions for you:
1. never call SPIFFS.begin in async callback - call .begin() method only once in your setup()
2. use PSTR/F decorators where possible (and corresponding _P methods - for example strncmp_P() )
3. avoid heap fragmentation using str.reserve(2048); - this avoid String class memory reallocation if you set the size carefully
4. never ever use + operator with String() objects - it's the worst that you can do for memory fragmentation - use str.concat() (with F decorator where possible) instead.
5. refactor your code so the huge str String is created only and only if %URLLINK% request is detected
All this gives you some more free RAM and minimize heap fragmentation...
By Sirquil
#84250 Pavel, I will implement your suggestions. Already took care of #1; rest I need to refresh my understanding.
"SdBrowse" web page provides a list of URL's; which at the moment does nothing, when a URL is selected. Previously to asyncwebserver used the following code:
Code: Select allelse if ((strncmp(path, "/LOG", 4) == 0) ||  (strcmp(path, "/README.TXT") == 0))   // Respond with the path that was accessed.
                              char *filename;
                              strcpy( MyBuffer, path );
                              filename = &MyBuffer[1];
                              if ((strcmp(path, "/FAVICON.ICO") == 0) || (strncmp(path, "/SYSTEM~1", 9) == 0) || (strncmp(path, "/ACCESS", 7) == 0))
                                   client.println("HTTP/1.1 404 Not Found");
                                   client.println();
                                   client.println("<h2>404</h2>");
                                   delayTime = 250;
                                   client.println("<h2>File Not Found!</h2>");
                                   client.println("<a href=http://" + publicIP + ":" +  LISTEN_PORT + "/SdBrowse    >Return to File Browser</a><br>");
                                   Serial.println("Http 404 issued");
                                   error = 1;
                                   end();
                                   client.println("Content-Type: text/plain");
                                   client.println("Content-Disposition: attachment");
                                   client.println("Content-Length:");
                                   client.println("Connnection: close");
                                   client.println();
                                   readFile();
                                   end();
readFile function would then download the file.
readFile function:
Code: Select allvoid readFile()
//     digitalWrite(online, HIGH);   //turn-on online LED indicator
     String filename = (const char *)&MyBuffer;
     Serial.print("File:  ");
     Serial.println(filename);
     File webFile = SPIFFS.open(filename);
     if (!webFile)
          Serial.println("File" + filename + "failed to open");
          Serial.println("\n");
          char buf[1024];
          int len;
          while  (len = webFile.read((uint8_t *)buf, 1024))
               client.write((const char*)buf, len);
          //delayTime = 500;
          webFile.flush();
          webFile.close();
     error = 0;
     delayTime = 1000;
     MyBuffer[0] = '\0';
//     digitalWrite(online, LOW);   //turn-off online LED indicator
How can downloads be accomplished with asyncwebserver? How to assign URL to path?
William
