I just bought ATMEGA32U4 integrated with ESP8266. I am new to this h/w part.
I am trying to flash the ESP8266 using the Audrino tool ending up in error.
My questions are:
1. I can upload some basic codes into the chip ATMEGA32U4 and is working. But when I select the board as Generic ESP8266 or NodeMCU 1.0 and upload the program, I end up in error "serial.serialutil.SerialTimeoutException: Write timeout the selected serial port serial.serialutil.SerialTimeoutException: Write timeout does not exist or your board is not connected".
Do I need to 'code' or initialize the ESP8266 (which is WiFi part) separately? If so, what if I upload another set of code? Will it erase the existing one?
2. How do I connect to the WiFi part (ESP8266)? I tried connecting from Mobile WiFi. It is getting connected, but nothing happens.
3. The board has a Micro SD port. Can I add an SD card and upload the program/code into the card? What is the use of the slot? Will it be erased every time I upload new codes?
4. By connecting to a different board, does it mean that ATMEGA32U4 is a board and ESP8266 is another board? And, does this mean that I upload code only to that particular board, say if I choose ESP8266, this means it will not affect ATMEGA32U4?
5. How do I find the correct board in Arduino IDE? What does it mean by selecting a 'board'?
Though these questions are basic, I do not know how to proceed as I am new to this h/w part. I code in some languages. But, I am having difficulty in understanding the h/w part.
Thanks for your time.
Srinivasan K
