By mmohamed2
#85601 Hi,
i was trying for days to fix that problem without success
can anybody help please
here's a part of my code
Code: Select all#include <LCD5110_Graph.h>
#include <Adafruit_MLX90614.h>
#define DEVICE_ID "Monitor1"
#define DEBUG true
#define REQ_CODE_ACK 1
#define REQ_CODE_VALUES 2
//84w * 48h
LCD5110 myGLCD(8,9,10,12,11);
extern uint8_t SmallFont[];   //8h * 6w font
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
int pinLM35 = A0;         //Pin A0 is for LM35
int fsrAnalogPin = A2;    //Pin A2 is for force sensor
int blinkPin = 13;        // Pin 13 is the on-board LED
String mSSID = "LibyaADSL-9a86";    //initial ssid and password
String mPASS = "BYRTPCRJAHPWQ";
//http request code
int service_code;
//wifi listen variables
String wifiBuf = "";
char character;
int connectionId = 0 ;
//sensor values
float sensor_mlx, sensor_heart, sensor_lm35;
int sensor_force;
  //init LCD
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  randomSeed(analogRead(7));
  //init MLX90614
  mlx.begin();
  //init serial
  Serial.begin(115200);           //Arduino-PC
  Serial3.begin(115200);          //Arduino-ESP8266\
  //init esp8266
  init8266();
  pinMode(blinkPin,OUTPUT);         // pin that will blink to your heartbeat!
  delay(200);
//init esp8266
void init8266()
    Serial.println("Init ESP...");
    sendCommand("AT+RST\r\n",2000,DEBUG);       // reset module
    sendCommand("AT+CWMODE=1\r\n",1000,DEBUG);  // configure as access point   غيرت 1 لي 3
    sendCommand("AT+CWDHCP=1,1\r\n",1000,DEBUG);  // HI اني ضفته
    delay(1000);
    sendCommand("AT+CWQAP\r\n",1000,DEBUG);     // quit the AP
    delay(1000);
    sendCommand("AT+CWJAP=\""+ mSSID +"\",\""+ mPASS +"\"",20,"OK");
    delay(10000);
    sendCommand("AT+CIFSR\r\n",1000,DEBUG);     // get ip address
    sendCommand("AT+CIPMUX=1\r\n",1000,DEBUG);  // configure for multiple connections
    sendCommand("AT+CIPSERVER=1,80\r\n",1000,DEBUG); // turn on server on port 80
* Name: sendCommand
* Description: Function used to send data to ESP8266.
* Params: command - the data/command to send; timeout - the time to wait for a response; debug - print to Serial window?(true = yes, false = no)
* Returns: The response from the esp8266 (if there is a reponse)
String sendCommand(String command, const int timeout, boolean debug)
    String response = "";
    Serial3.print(command); // send the read character to the esp8266
    long int time = millis();
    while( (time+timeout) > millis())
      while(Serial3.available())
        // The esp has data so display its output to the serial window
        char c = Serial3.read(); // read the next character.
        response+=c;
    if(debug)
      Serial.print(response);
    return response;
//Process wifi request
void procWifiRequest(String content)
    int indexEnd;
   int dataSize = content.length();
    char data[dataSize];
    content.toCharArray(data,dataSize);
    Serial.println("-------------------- Received Request --------------------");
    Serial.write(data, dataSize);
    int index = content.indexOf("+IPD,");
    connectionId = content.charAt(index+5) - 48;
    index = content.indexOf("action=");
    service_code = content.charAt(index+7) - 48;
    Serial.println("Service code = " + service_code);
    if(service_code == REQ_CODE_VALUES)
        responseSensors();
         String response;
         response = "result=ACK";
         response += "&id=";
         response += DEVICE_ID;
         sendHTTPResponse(connectionId,response);
i got
Appreciate any help!
